Hose Collapse on Acceleration - See Video
ronzara
Year and Model: 850 GLT 1997
Post by ronzara »
I know this should not be happening. What would cause this?
I believe this may be some of my low rpm throttle problems.
Thanks everyone.
RZ
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2658 times
Been thanked: 1248 times
Post by matthew1 »
Can you make the video public? It's not viewable currently.
Also -> Amazon link
ronzara
Post by ronzara »
SORRY. Video now Public... MY BAD! :D
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
A cheap hose is what's causing that (that one ain't OEM), and yes, that's what's causing your car to run terrible at low RPM.
Replace it with either a silicone or OEM hose. And check for any others doing the same thing too.
'98 S70 T5
2016 Chevy Cruze Premier
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Also get that vacuum tree replaced. I think there is a line that is suppose to be connected there as well.
ronzara
Post by ronzara »
I have just read somewhere that I should have a Vacuum line running from The "TREE" to one of the nipples :shock: on the Boost Solenoid.... I think THIS COULD BE part of my problem.
All the ones on my car are capped off except for the one that's missing. I don't see any and vacuum lines off anywhere. Maybe the one that IS attached to the boost solenoid is tucked under or behind something, and I've missed it somehow. :oops:
On another note:
I have noticed a "clicking" sound coming from a small vacuum sensor under the air intake tube.... Drivers side, behind the back of the radiator under the air intake tube.... this part has a vacuum line going in the top and out the bottom... with a small wire connector plugged into it.
It was sounding like a valve tapping,... and I pinpointed the sound coming from this part.
Is it Defective, or is this normal?
I pulled the lines off each end and sprayed in it with crc electrical cleaner, didnt seem to change anything.
On a side note, I installed new ACCEL plug wires, the car ran worse. 2 wires were bad right out of the box... had to take em back to Advance Auto. I DID notice, however that the car ran a little better with the new coil wire and old plug wires.
Is it possible a Bad or Failing Coil could be causing the car to run poorly ?
We tried starting the car with the coil wire on and then off (but held very close to the coil), the car fired quicker with the wire ALMOST on the coil
