V8 Oil / Fluid Leaks
99TurboBrick
Year and Model: 1999 S70 T5 Manual
Has thanked: 35 times
Been thanked: 13 times
Post by 99TurboBrick »
Hello,
I had an inspection done a XC90 V8 I'm considering purchasing. These were the photos the shop provided with the text:
"During the inspection, we observed a noticeable leak from the timing cover
seal. Additionally, there are other areas beneath the engine exhibiting signs
of fluid presence, though we were unable to identify specific sources at this
time."
I know timing cover leaks are a known issue, any guesses as to the other with the unidentifiable source?
Umh2SmVwR3N0MGpHR1JaT09rYk1ObnNxMHI5S2hZS09PTzRvZ2dObUJyK1ZhazdVYWc4R0o2VXFyeVg2TXcwZA_s.jpeg
Umh2SmVwR3N0MGpHR1JaT09rYk1ObnNxMHI5S2hZS09PTzRvZ2dObUJyK1ZhazdVYWc4R0o2VXFyeVg2TXcwZA_s.jpeg (110.53 KiB) Viewed 382 times
ggleavitt
Year and Model: 06,08 XC90 V8
Has thanked: 23 times
Been thanked: 125 times
Post by ggleavitt »
Might be old PS fluid, might be a seeping water pump, might be from the oil cooler, there's really nothing other than that to leak. I see folks write about RMS issues but in my estimation those are rare and most are misdiagnosed PS pump leaks. Timing cover is seeping versus outright leaking, that's a good thing. You could always scope the back CB shaft valley if you're really doing this assessment in detail, see if there's a hole or not- https://www.swedespeed.com/threads/new- ... ft.666250/
Does not look bad at all TBH, seep progression is reasonable for the motor.
2006 V8 Ocean Race #740/800 200k, 2008 V8 Sport 183k
