removing wires from wiring harness
dkellogg3
Year and Model: 2007 3.2 XC90
Post by dkellogg3 »
So I have the left blinker/driver door open issue due to a broken wire. It's the back wire right at the harness that clips to the door. Needs to remove the remnants of the wire and the pin. Any help on how to get the pin to release?
BBowen6123
Year and Model: 2003 XC90
Post by BBowen6123 »
I have EXACTLY the same problem as your pictures show. Did you ever find a resolution?
If so, let me know on this post. Minnesota Bruce
rsnuke
Year and Model: 2010 XC90
Post by rsnuke »
I have the same issue... how did you pop out those metal inserts out from the plug? so i can solder a new wire?
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
There are pin removal tools you use for this job. Try search on Amazon. Get a set of them since you won't know which one you need.
Has thanked: 1504 times
Been thanked: 3817 times
RickHaleparker had a thread here on thst with links, I’ll try to find it
Year and Model: 2004 V70 2.5T
Been thanked: 471 times
Post by cn90 »
Below link is a very good video. Once you understand how this is designed, then it is easy. Now if you carefully remove the remaining female end and gently pry it open to remove the broken wire, you may be able to re-use it. Of course, if you can find brand-new identical female end, then use it.
ggleavitt
Year and Model: 06,08 XC90 V8
Has thanked: 23 times
Been thanked: 126 times
Post by ggleavitt »
Good view of the pin removal. One challenge may be the new connection. You'll really want a new crimp on the connector which may mean some new wire and a splice. If you end up going in this direction, make the new wire that crimps to the pin/socket as long as possible (like 1 inch?) and connect to the old wire with some good heat shrink and preferably a solder joint in the rubber passage between dorr and front quarter. You're wanting to get the new wire in the connector for a solid mechanical fit but keep the flex point of the splice itself farther back. Hope I'm explaining this correctly. One alternative is to drill out the pin/socket and run a single piece of wire throught the nylon connector body and splice on either side of the connector but I'll guess that takes some skill to avoid the other conductors in the connector body.
2006 V8 Ocean Race #740/800 200k, 2008 V8 Sport 183k
Post by cn90 »
One problem w door wiring loom...once a wire is broken, others follow soon.
So...best is to get a new wiring loom.
packetfire
Year and Model: 2010 v50 2.4i
Has thanked: 17 times
Been thanked: 30 times
Post by packetfire »
Here's a tool kit that will do for $6
https://www.amazon.com/DINYO-Upgraded-T ... B0DQNMKHY7
1982 240DL: Drove it 32 years and 1.5 million miles (sold, even still had mint leather!)
2001 v70 2.4T: The most expensive $1500 car I ever bought ("Volvo Turbo" - what an oxymoron!) (sold)
2004 v70: Far less fatally-flawed v70 - It served well (sold)
2010 v50: Smaller, slightly sportier wagon. Its got a spoiler, so I upgraded with sway bars!
