1998 S90 PNP wiring - wires pulled out of the harness
I was replacing my PNP switch, everything was going well until I tried to unplug the old one. The wires pulled out of the harness plug side. Now I cant find a diagram with the wire colors and location to put it back together. Im dead in the water as they say. can anyone help me?
Reason: Edited title. Please, no "HELP"s in titles.
If anyone has a picture of the plug or knows the pin numbers i believe they are:denzillee wrote: 06 Nov 2018, 10:23 I was replacing my PNP switch, everything was going well until I tried to unplug the old one. The wires pulled out of the harness plug side. Now I cant find a diagram with the wire colors and location to put it back together. Im dead in the water as they say. can anyone help me?
1234
5678
I have found a wire diagram but not the pin number locations. I plan on spicing the wires to the PNP switch once i have the correct pin numbers or picture.
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
If the plug has 8 positions and only 5 wires try this:
Plug B4
1 Green
2 Green/orange
3 Yellow/white
4 Pink
5 Brown/black
6 not used
7 not used
8 not used
If this isn't correct let me know and I look again. This info is from S/V 90 Greenbook on wiring diagrams.
Plug B5 is the other posibility
1 Blue/yellow
2 Brown/pink
3 Blue
4 Blue/pink
5 Blue/green
6 Brown/white
7 Green/brown
8 Green/white
Plug B4
1 Green
2 Green/orange
3 Yellow/white
4 Pink
5 Brown/black
6 not used
7 not used
8 not used
1 Blue/yellow
2 Brown/pink
3 Blue
4 Blue/pink
5 Blue/green
6 Brown/white
7 Green/brown
8 Green/white
1988 Volvo 760 Turbo Wagon
it is the B5 as there are 8 pins and 8 wires. with the positions being
1234
5678
this seems to work. the only issue I have is a check engine light but my 2 OBDII readers don't find a code. must be a trans code from me guessing at wire locations.
thank you.
1234
5678
thank you.
dm635
- Year and Model: '96 965
- Been thanked: 14 times
If you want to PM me your phone number I'll text you some pics of the connector. I had to swap an engine that also required transmission removal. A couple of the wires did pull from the connector.
Went to PULL A PART and snipped off the 3 connectors at the transmission with pig tails if I need to address any problem on mine. So far it's OK so I have this small wiring harness with the 3 connectors still connected. If you PM list the color of the PNP switch wires. The harness I have is all 3 connectors at the transmission.
96-964
09-V70
05-325i
86-635CSi
Previous- 83 245T, 84 242, 85 242T, 92 960, 94 960, 95-964, 95-945, 91-780t, 96-960, 98-XC, 91-745,
09-V70
05-325i
86-635CSi
dm635
I've taken pics and texted to you. Let me know if it was the correct connector. Thanks Dave
96-964
09-V70
05-325i
86-635CSi
09-V70
05-325i
86-635CSi
- 3811 Views
Last post by packetfire
- 14 Replies
- 4660 Views
Last post by CIK7
- 5660 Views
Last post by gnalan
- 1005 Views
Last post by DEWFPO
- 873 Views
