Here's how to service and change the filter in the transmission in your S80: S80 Transmission Service. I got my filter kit here for $37: Filter Kit.
NOTE 1: The above link says the bolts are 12mm, but on my car they were 10mm.
NOTE 2: This transmission holds 13 quarts of fluid. The procedure described in the link only changes out 6-7 quarts. So, you may want to perform a flush or drain/fill/drain/fill procedure in addition to the filter change to get most of the old fluid out.
NOTE 3: To do a drain/fill/drain/fill procedure you drain out what you can, refill, drive a while (or run the car with the wheels off the ground) to mix the fluid, drain again and refill. This dilutes the old fluid with new until the majority of the fluid is fresh. I.E.: this transmission holds 13 quarts, so if you drain and fill with 6.5 quarts the first time, you have 6.5 quarts of old fluid and 6.5 of new, for a 50/50 mix. The second time you do a drain and fill, you will have 3.75 quarts of old and 9.25 quarts of new, for a 75 new/25 old mix. The third time you do a drain and fill, you will have 1.875 quarts old and 11.125 quarts new for a 87.5% new/12.5% old mix. This required 19.5 quarts of fluid. Is it worth it? Well, flushes run about $200, and a simple drain and fill is about $75 at your local lube shop. This transmission uses Dexron III, which is $1.77 at the local WMart. $1.77 X 20 = $35.40 for the fluid.
NOTE 4: Do you even need to do this? Volvo says the fluid is "lifetime." Lifetime of what? The transmission! Once it's out of warrantee, they don't care if it lasts or not (IMHO). Considering that a new tranny is $2500, I think it's cheap insurance. For more discussion look here: ATF Fluid Change Not Recommended?, here: ATF Fluid Change Myth?, and here: Swapping ATF.
S80 Transmission Service/Filter Change
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
- Has thanked: 17 times
- Been thanked: 35 times
Thanks! Pinned in the repair database.
vegasjetskier
If you have an AutoZone, Pep Boys or Advance Auto Parts nearby, you can save a few bucks on the filter getting a transmission filter for a 2000 Chevrolet Impala 3800 (3.8 liter engine). The filter will fit because the transmission is the same (General Motors 4T65E).
$14 @ all of the above.
- 2285 Views
Last post by father ted
- 626 Views
Last post by hideogumperjr
