Volvo S80 2.4T - Cleaning out the PCV system
ndphotonl
Year and Model: 2001 S80 2.4T
Has thanked: 27 times
Been thanked: 33 times
Post by ndphotonl »
Performed some maintenance which is highly recommended for all S80 drivers!
Repaired the PCV circuit, as I suspected the PCV system to be clogged up good. I noticed quite some oil when I mounted the silicone intake. And it seems I was right, as 2 of the 3 holes were fully clogged (car has 316k kms on it). I bought a kit which also replaced the long hose, but after some inspection, that looked like a lot of work for a thursday evening.
ImageVolvo S80 2.4T PCV Repair by Andy Ramdin, on Flickr
Checked all hoses en cleaned the banjo bolt + hole. Replaced the oil separator and the 2 other connecting hoses. The pictures speak for themselves...
Gunk extraordinaire
On a positive note, the valves all looked ok :)
ImageVolvo S80 2.4T Clean Valves :) by Andy Ramdin, on Flickr
Big advantage when you drive a S80: you have quite some room for DIY maintenance.
Volvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
Your pictures confirmed what I thought your system would look like. The build up in the two block holes is important to clean out well all the way into the pan. Great work.
If you don't have it together the front banjo bolt on the intake trick I use - put it on only a few threads then seat the intake. Gives you a little more wiggle room. Some have trouble with this bolt. Just make sure you don't cross thread - finger tighten as much as you can.
Next maintenance item I would do is drop the oil pan, clean it out and change out the o-rings.
ndphotonl
Post by ndphotonl »
Yeah the banjo bolt was a tough cookie to crack. I stepped back for a couple of minutes after trying too long. I have small asian hands, but even with small hands, space was tight. After taking a small break, I tried again and it actually gripped :)
Next maintenance is already planned, changing the fuel pump. But I will do the oil pan cleaning someday!
FlickR images
