The Transmis RMP goes to 3,000 before it goes into 3rd gear. Topic is solved
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Singh
Post by Singh »
I have a 1989 740 GL Volvo. It is not going into gear. The RPM goes to
3,000 before it goes into the 3rd gear reving at a high level. The cable that
goes to the trottle body is not going into the sleve at the top of the mount.
[email protected]
Post by [email protected] »
replacing the cable will likely solve the problem; when it ages it stretches and then you have delayed shifting
LaRy
Year and Model:
Post by LaRy »
i Agree with JGolden, that it sounds like a bad kick down wire but I think that some treads in the wire are broken so the wire has split somewhere. Then it will not go back by the return spring inside the gearbox. If you pull the kick down wire between yuor fingers it should run really smooth and nice and it should be no probelm for the wire to go back.
