98 S90 vacuum reservoir location Topic is solved
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
S90ken
Year and Model: 1998 S90
Post by S90ken »
My 1998 Volvo S90 AC is cutting out under acceleration and/ or going uphill. Resumes afterwards. I found that one check valve on firewall was bad and replaced with a brand new OEM part. Also replaced several rubber vacuum connector lines on firewall around the two check valves that looked suspect. I now suspect the bellows under dash or perhaps more likely the vacuum reservoir. Can someone tell me where the reservoir is? Any other ideas? Thx.
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
It appears to be under the front of the car. Search: 1997 Volvo 960 a/c problem
1988 Volvo 760 Turbo Wagon
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
lummert wrote: 14 Aug 2017, 19:59It appears
Nothing inside vehicle except vacuum pots to redirect air flow...here's how its setup on firewall
93Regina
Post by 93Regina »
S90ken wrote: 14 Aug 2017, 15:48My 1998 Volvo S90 AC is cutting out under acceleration
I have no idea how electronics are setup....cutting out means what?
If yours has a MAP sensor, ECU may be programmed to cut-off AC under low vacuum "pressure" (WOT type conditions)
S90ken
Post by S90ken »
1) I had looked under that volvo 960 post earlier and looked under my s90 for reservoir. No luck. I will look again. 2) thanks for the firewall diagram. That is where i assumed problem was originally. Replaced one of the check valves that i found was bad and a couple of the vacuum lines that appeared deteriorated. 3) cutting out means that under acceleration the air flow from vents in car either greatly diminish or disappears altogether depending on how hard the acceleration is. Actually it also does this even if the AC is NOT on and controls are set just to blow regular air. Have had car a long time. This is a new phenomenon.
S90ken
Post by S90ken »
Topic NOT solved. Hit that button by accident.
93Regina
Post by 93Regina »
S90ken wrote: 15 Aug 2017, 02:01...looked under my s90 for reservoir. No luck
Years ago, in many vehicles, a mechanical slider (or rotary) switch controlled a vacuum switch to activate various "vacuum bellows" for redirecting air flow (vacuum bellows: 10, 20, 21, 21).
Newer vehicles, I don't know. Diagram shows (2) servomotor and a (13) solenoid valve. One might control hot water, and the other might be an electronic vacuum switch.
On my 1993-940, they used a vacuum controlled switch to vary amount of hot water flowing...vacuum pot was located in engine compartment, and hooked inline with a rubber hose. This vacuum pot needs to be changed...mine leaked anti-freeze.
S90ken
Post by S90ken »
Thanks folks. Problem IS solved now. Turns out when I replaced one of the check valves ( vacuum pots) on firewall I had split end of one of the new hoses I put on. AC great now even under acceleration! Will run you out of car. Tha ks!
