240 rev problem
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
mike C
240 rev problem
Post by mike C »
Hey all, I've been having this problem with my 82 240 wagon. When I start it up, the engine revs up really high. There's nothing I can do to make it go down. When put it in drive, it goes down, but while i'm driving, it will accelerate on its own without me pressing the gas pedal. Also, sometimes it will not respond to me pressing the gas pedal. Anyone know how to fix this?
ozzimark
Year and Model:
Post by ozzimark »
i used to have this exact problem. it's caused by either the wires going to the idler motor shorting out, or the idler motor itself malfunctioning. check the first before the second cause the idler motor is kinda expensive and is a pain to remove
arete
Post by arete »
I had a similar problem with my 81 240 DL wagon. It was the low idle wire. I disconnected the bigger plug and then adjusted idle. I also went into the wire harness for that system and cut the wire and then put the plug back. It contained about 4 wires. SMOG people couldn't tell that way and I passed with it disconnected.
