740gl 1989 spark plug wire order
This topic is in the MVS Volvo Repair Database » 740GL 1989 spark plug wire order
Crispy789
Year and Model: 740 gl 89
Post by Crispy789 »
Like a true dope I was changing plugs and realized I needed to replace the wires also, but I didn't write down the order I took them off in. Looking at the engine from in front the car, the distributor is directly behind the 4cyl engine with 4 wire holes in a line from left to right. Does the first hole go to the first plug, second to the second, third to the third, etc? If not, can I get the correct order?
Kmaniac in California USA
Post by Kmaniac in California USA »
I recently replaced the distributor cap on my 1986. If you take off the distributor cap, you will see that each wire plug is labeled with the cylinder number it supplies. But to save you the aggravation of pulling the cap, here is the order on the cap starting on the driver's side of the car: 2 - 1 - 3 - 4
Now, if the cap used on a 1989 is different than one used on a 1986, then all bets are off.
The cylinders on the engine are numbered sequencially with the one closest to the front of the car as #1 and the one closest the firewall as #4.
I hope this helps.
Chris the "K MANIAC"
1986 740 GLE
(5) 1964 Chrysler 300-K's
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Chris, you win the bet again! :)
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Howling
Year and Model: 1990 740 turbo
Post by Howling »
Thats the order on my 90 740 turbo. lol so yea it works.
