How many of you have done this?
I am thinking about tightening it about two turns.
Modifying the Wastegate actuator rod...
Modifying Your Wastegate actuator rod: Performance mod on a budget
Reys
- Year and Model: 850T estate '96
Hey, I went and adjusted my waste-gate actuator and realized I only did two half turns instead of full turns
, does the safe parameters of this mod mean turn the flat wings on the adjustment piece over twice or 4 times to make 2 full turns
Just a bit confused. Thanks
JRL
- Year and Model: Several
- Been thanked: 16 times
I do this on almost all my Volvo turbos
the 4.4 Motronics (94-98) can handle up to 3+ turns but you don't want to do that. You will actually get too much boost almost off the lnie andin bad weather can be a bit scary.
I would say your 2 turns is ENOUGH
The ME-7 cars usually take less, up to one turn, sometimes only a 1/2 turn.
Without a boost gausg and the "correct" method, it's a guess. Do a 1/2 turn at a time, especially after the first turn. You will be able to tell the difference.
If you go too far, your mileage will really suffer plus you really won't enjoy more benefits from over tightening.
Im me with any questions, I suppose I've done more of these than anyone with all kinds of Volvo turbos
IVIUSTANG
- Year and Model: 2006 XC70
- Been thanked: 4 times
Are there any tutorials on doing this? I am not very familiar with turbos, a picture and explanation would be nice for many on this site. I have always wanted a little more juice off the line, I raced a Prius at 9000 feet and he beat me off the line for a short distance! I found my turbo took longer to produce 15 PSI boost at this altitude.
Regards,
- Jesse
Regards,
- Jesse
1998 S70 T5 SE 290,000 KM sideswiped total loss(Sweet ride!)
2007 S60 2.5T loaded 63,000 KM SOLD!
2006 XC70 350,000 KM, 2" BadSwede lift kit, steel skidplate, Hilton Stage 1 tune, big burly tires
2008 S80 V8 245,000 KM SOLD!
2015 V60 T5 Premier+ 98,000KM
9394volvo850s
- Year and Model: 93 850 5spd 94 850T5
first have a boost gauge installed. factory is not good enough. boost cut with factory ecu is 15 or 15.5 psi. dont do more then 2 turns at a time. 12 - 13psi is safe for stock. be carefull not to boost more then 10psi lower then 3k rpms. bend rods low rpms.
93 850 5spd 320k (the daily)
94 850 T5 190K (race car)
95 T-5R wagon yellow (summer wag)
90 745 5spd 295k (winter wag)
67 122 2 door 4spd 69k
mindshadow
- Year and Model: none
Is this only good for the high boost models or would this also work on a '98 V70 XC?
- 582 Views
Last post by sordidlove
- 1055 Views
Last post by aloera
- 1592 Views
Last post by turtle1615
- 783 Views
Last post by volvoAgX
- 768 Views
Last post by ericmci
