Koni Struts, very poor finish
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
This topic is in the MVS Volvo Repair Database » Koni Sport Peeling Paint
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Post by RussB »
I got this pair of Koni Sport (yellow) struts & shocks in July of 2014. In March of 2015, 1 strut failed and FCP Euro promptly replaced it. Here's what they look like today,
13 months old,
5 months old,
The problem seems to be the paint bubbles up, and the steel under the bubbling is already rusted. Looks like poor metal prep to me ??? I have contacted Koni to see what they have to say
'00 S70, '04 S60 and the never ending quest for Stage Zero
beigg
Year and Model: 850 97
Post by beigg »
that sucks! keep us posted.
ugh smh 850 Turbo fridge
RussB
Post by RussB »
beigg wrote:that sucks! keep us posted.
To sum up the reply,
The KONI Sport yellow dampers are produced in Oud Beijerland, NL. Each country has its own regulations regarding paints, specifically regarding the removal of solvents and using water based paints, which can present adhesion and long term oxidation issues, in areas with harsh winter weather and regularly salt and chemical treated roadways...
They offered to send me some touch-up paint. I passed
I bought a set in '06. They actually rotted to the point where the fluid leaked out of the shocks and struts. FCP replaced them, because they stand behind their products.
These new Konis are poorly finished just as they were in '06.
I sprayed the struts & shocks with some Rustoleum rust converting paint after cleaning them up as best as I could
crlande
Year and Model: 240DL;850;S70
Has thanked: 1 time
Been thanked: 36 times
Post by crlande »
Does your state use salt brine for treating the winter roads?
https://www.washingtonpost.com/local/tr ... story.html
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
For some reason, that doesn't look like an original paint ?
RussB
Post by RussB »
oragex wrote:For some reason, that doesn't look like an original paint ?
It is the original paint
oragex
Post by oragex »
Does the paint have the same thickness in all areas? The paint finish on the areas where it didn't peel doesn't look like a factory finish and the way is bubbling shows the paint was applied on a rusted surface. Looks like they sold/sent you an old repainted strut.
