2001 S60 Any preventive maintenance proposal? Topic is solved
This topic is in the MVS Volvo Repair Database » S60 Preventive Maintenance Parts
zoli_m13
Year and Model: S60 2001
Re: 2001 S60 Any preventive maintenance proposal?
Post by zoli_m13 »
RIGHT BACK DOOR also shiny and has a new look after repainting (it was a GRATIS by the bodyshop)
2001 VOLVO S60 2.0T A/T 245K+ miles
https://goo.gl/photos/jS1z777LDqJSQqPDA
zoli_m13
Post by zoli_m13 »
BEFORE (ugly and broken front bumper)
AFTER
zoli_m13
Post by zoli_m13 »
… finally a real fun: ETM cleaning on the bench! Reason: slightly wawing RPM at hot idling, stalling at cold idling, difficult to accelerate at low rev's.
Pretty good step-by-step DIY video available here:
[youtube][/youtube]
BEFORE
AFTER
Has thanked: 1505 times
Been thanked: 3818 times
That’s was a dirty filthy throttle body
zoli_m13
Post by zoli_m13 »
Found an ugly oil drops under the right side of the engine - diagnosed as oil pump failure by myself. I thought Will be done by myself as an easy fix - what a mistake it was!
This hub is a part of maintenance plan at mileage 200K.
My engine has 240K.
Finally, VOLVO delareship did the job - FORD and OPEL rejected it due to missing the special tool for timing shaft locking. The full set (1 hub at the exhaust valves plus gaskets of the camshafts and the plastic cap including the labour fee) was USD 532.
zoli_m13
Post by zoli_m13 »
Timing belt and ribbed belt kit replacement - including water pump, generator flywheel, tensioners and pulleys.
The water pump was still good shape (excellent bearing) like the other pulleys - only the timing belt tensioner pulley/bearing was bad condition after ca 60K miles - little bit surprised me. I won't wait 100K miles for the replacement, but will following the 60K interval.
Oil and auto tranny oil change with Mahle Filter after 5K miles.
zoli_m13
Post by zoli_m13 »
Rear anti-roll bar endlink replacement due to knocking sound at cornering by low speed.
Bushing also ordered, however both looks OK.
Photos: see the link below.
zoli_m13
Post by zoli_m13 »
Rear anti-roll bar endlink replacement due to knocking sound at cornering by low speed - with photos:
zoli_m13
Post by zoli_m13 »
Front anti-roll bar endlinks replacement - now it rock solid!
zoli_m13
Post by zoli_m13 »
Rear left side door panel handle repair by zip-ties due to a broken tab - thx for the idea by cn90
viewtopic.php?f=10&p=381478#p381478
