Gas pedal swapability RPM dropping out Topic is solved
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
Problem RPM drops out around 2-300RPM when pedal is lightly pressed, mildly annoying. Car almost stalls and also can be felt at low speeds. My first thought was the ETM being a 2001 vehicle, however i am reading many symptoms of a bad ETM an none mention RPM drops.
Could it be the gas pedal?
I have a spare gas pedal from my auto (brushless) but its different to the manual (brushed) (wires are same colours)
Ive given the brushes and tracks a noticable cleaning but problem remains
Question are the pedals coded to vehicle?
If i swap will i damage the ecm, ??
brushless auto and brushed manual gas pedal
brushed gas pedal 2001
2001 XC70 factory M58
2002 XC70 auto (parts car)
darrylrobert
havent test driven the car yet but swapped pedals and car appears to idle better and engine seems to respond better.
Has thanked: 1505 times
Been thanked: 3818 times
What were the part numbers of the pedals you swapped?
Volvo web store has fitment guides that are pretty reliable for determining parts compatibility and supercessions
darrylrobert
Brushless pedal has this written on it 30606006, 6PV 00853702. brushed pedal 9157553.
note this is a RHD vehicle, it appears there maybe LHD RHD variations
brushless part number
pedal swap.jpg (23.75 KiB) Viewed 647 times
darrylrobert
Just back from a short test drive and can report a noticeable improvement in idle, i have an IPD poly upper mount so i can feel everything, i can shuffle forward and back without stalling. Not sure what years got this brush contact pedal but worth a look at if your vehicle is playing up.
Note the connector is needed for changeover
Brush contact throttle pedal
Testing before connector swap
