2006 XC70 rear diff leaking Topic is solved
Rvolvos
Year and Model: 2006 xc70
Has thanked: 73 times
Been thanked: 23 times
Re: 2006 XC70 rear diff leaking
Post by Rvolvos »
Added text to the photos.
2006 XC70 2.5T 238k
2012 S60T6 95k rip
2011 C30 T5 M66 105k Totalled RIP
2006 V70 2.5T 184k RIP
2011 C30 T5 AW55-50SN 99k sold
Rvolvos
Post by Rvolvos »
Prepped the replacement rear differential. Unfortunately the coupler from the propeller shaft was left behind in companion flange/ oscillation damper and I could not remove it with the push screws from behind and pb plaster. Ended up punching a hole in the prop shaft end cap to reach the nut to remove the whole damper.
Reused the oscillation damper and DEM from our car (rear differential came w.o. a Dem). Put in a new filter, temp switch, axle seals and AOC breather element. I could not remove the pump without damaging it. Tested it with 12 Volt and it’s working and leave it as is. The final drive seal is on back order 2 months out and decided not to split the case because of the o-ring not available. And test it as is.
Waiting on the last bushings for the rear sub frame to come in before installing it in the car and fill it with oil.
2006 XC70 2.5T 238k
2012 S60T6 95k rip
