I had a go at trying to fix a rear seatbelt that won't pull out at times. I didn't have much success, stopping when I saw it was getting quite involved.
What's the way to deal with these rear belts?
Stuck Rear seat seatbelts on 2007 XC70. Fixable?
- DavidE7
- Year and Model: 01-07 V70, S60, XC70
- Has thanked: 53 times
- Been thanked: 62 times
Are the little button shaped plastic stops missing from the rear seat belts? These little plastic stops keep the belt from retracting too far and locking in the spool mechanism. See the Volvo parts catalog picture below. The buttons are numbers 2, 3, 8, and 9. I have had problems getting the seat belts to pull out when these buttons are missing and the seat has been folded flat. The upper buttons are the important ones to keep the seat belt from retracting too far into the spool. The lower ones keep the seat belt buckle from getting lost under the cushion when putting the seat back up from the folded position. I had to remove the seat belt bolt (item #5) to slacken the belt and get it to pull out again when the mechanism was locked. Sewing or gluing buttons to the correct locations fixed the problem for me. there should be some faint witness marks for where the buttons were located. These buttons can be removed from junkyard vehicles with a knife or screwdriver prying underneath the plastic. Then you need to re-open the push through hole in the seat belt using an awl. Push the replacement into the hole and secure it with a good coating of superglue coated on the plastic parts and soaked into the belt fabric.
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 224,000 miles
2004 Nautic Blue XC70 2.5T 251,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 275,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 200,000 miles
P2 Volvos for every person in my family
AylmerQc
- Year and Model: 2007 XC70
- Has thanked: 60 times
Thanks.
The little plastic stop is there.
What I tried after writing this post is banging on the back of the seat and 9 times out of ten this worked in allowing the belt to be pulled out.
I imagine however the retractor is built, it's gummed up a bit. Ideally it probably needs a bit of WD 40 or similar lub, I'm guessing...
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 114 times
- Been thanked: 263 times
I've had this happen, try retracting the seatbelt with the seatback in a position other than upright. It should eventually retract if you move the seatback up and down while pulling on the seatbelt.
2003 XC 70 (sold)
- DavidE7
The plastic covers come off the top of the back seat but it is very easy to crack and damage these covers. Once the end covers have been removed, you will be able to see the seat belt spools and blow them clean with compressed air. I tried to find instructions and pictures in Vida/Dice and found nothing.
David E
