I replaced the fuel pump assembly on this car, however when refilled with fuel, the new o-ring on the driver-side is leaking. I've tried tightening the ring, but it is still seeping. What's the best way for me to remove some fuel so I can remove the tightening ring & sending unit to see where the problem lies? Can it be siphoned? Can I release the filter connection and let it drain? Put a large container under the tank and open the ring? Another option? Thanks for the help.
Marlin
2001 S60 T5 How to remove fuel from tank.
FarmallM51
- Year and Model: 2001 S60
- Krons
- Has thanked: 193 times
- Been thanked: 202 times
Maybe too obvious…go for a drive?
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- Has thanked: 927 times
- Been thanked: 1000 times
Yes it can be siphoned. I have used a rotary crank pump with about 1/4 inch OD stiff, clear plastic line into the tank. The pump I used could siphon without cranking after getting it started. The clear tube is needed to see if you are lifting the fuel to the pump. Getting flow started can be fiddlly.
The small tube is needed to get past the antisiphon valve. The tube may have to be twisted to get down to the fuel level. A small tube will siphon very slowly, but it will work.
FarmallM51
I got to ask, do you own a Farmall M tractor?
See my tractor ownership list below.
FarmallM51
Yes. 1951 Farmall M & 1960 Fordson Dexta.
FarmallM51
After sitting for 24 hours with a full tank of fuel, the seepage around the o-ring seems to have stopped. I don't know what caused it to finally seal, but I'll keep an eye on it for a few days.
Vova585
- Year and Model: 01v70xc,2016xc70...
- Has thanked: 155 times
- Been thanked: 142 times
Do yourself a favor and fix it right. Fuel leaks are not self sealing. Give it proper condition-hot/cold, full tank-and it will be back. I would buy new O-ring and plastic "cap screw ring" and replace everything to assure worry free driving.
FarmallM51
I tend to agree. It's sealed up enough that I'm comfortable driving it for a few days to get the fuel level down. I'll order a new o-ring and the screw ring is a good idea also. Thanks.
- 38 Replies
- 8063 Views
Last post by jking4020
- 10 Replies
- 6308 Views
Last post by SuperHerman
