Green electrical connector crimp tool?
darylrobert
Year and Model: V70 240 740t xc70
Has thanked: 6 times
Been thanked: 42 times
Post by darylrobert »
Ive sourced the green connectors Volvo use, they are JAE brand IL-AG5 series connectors. Does anyone know what crimp tool to use??
I recycle, re-use salvaged wires and plugs but sometimes have to make them. Note: de-pinning these can be a challenge, there are two small tabs that need to released at the same time. Also the male pin (shown) goes with the Female looking connector, its easy to get male female pins and connectors mixed up
Green JAE IL-AG5 connectors
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
Perhaps Allied Elecctronics Supply https://www.alliedelectronics.com/srch.html can supply appropriate crimp tool.
crasbe
Year and Model: 02 S60, 98 V70 (EV)
Has thanked: 31 times
Been thanked: 79 times
Post by crasbe »
It is difficult to judge the size of the connectors, but I had good luck with the Engineer crimpers:
https://www.engineertools-jp.com/produc ... ing-pliers
You'll have to measure the width of the crimp connector to select the correct die width and then select the appropriate crimper for the task.
They are single stage, meaning you have to do two operations for the full crimp, but in many cases that is good because you don't have to get a specialized crimping die.
Check out my 3D Printed Parts for Volvo P2 and P80 on Printables :D
crasbe
Post by crasbe »
Maybe you can also share the exact part numbers here in case someone stumples upon this thread in many years and wants to source the connectors and pins too :)
darylrobert
crasbe wrote: 25 Aug 2025, 03:56 i checked out your 3D prints, how difficult would it be to print a volvo button, not the whole thing just the moving part pictured?
p2 button
p2 button
p2 button.jpg (23.91 KiB) Viewed 366 times
ive had some custom circuit boards made, they make the buttons in white plastic so the light comes through, then paint them grey/black
P2 ECC custom made buttons
crasbe
Post by crasbe »
That is probably possible, however it would have to be printed in SLS (powder) due to the high amount of details and the small size.
The print itself is simple and you can even color the part similar to the original one or even print it multi-colored with MJF (Multi-Jet Fusion). The difficult part would be the modelling and personally I don't really have a use for it.
DavidE7
Year and Model: 01-07 V70, S60, XC70
Has thanked: 53 times
Been thanked: 62 times
Post by DavidE7 »
I use this Matco crimper for almost everything automotive:
https://www.matcotools.com/catalog/prod ... mping-tool
I purchased this tool for home and for work after seeing it many years ago on a Chrysler mechanic's workbench. If you are very careful, it works for almost every electrical connector brand. There are many copies and other suppliers for the same tool. The key detail is to get the 5 different size crimps with the double curve on the seat side to roll the two crimps over and into the stripped wire bundle.
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 224,000 miles
2004 Nautic Blue XC70 2.5T 251,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 275,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 200,000 miles
P2 Volvos for every person in my family
darylrobert
thanks i bought a crimping tool that i am 90% happy with. it does a neat job of crimping the wire and insulation at the same time but has a tendency to slightly bend the terminal.
wahiddd
Year and Model: 2001 S40 2.0T
Post by wahiddd »
For those JAE IL-AG5 connectors you'll want an open-barrel crimp tool, usually the Engineer PA-09 or PA-21 works fine. They're not "official" but they get the job done without destroying the tabs
