under the impression that the oil sump to block was sealed with the orange (i believe elring el-liq 74, correct if wrong) anaerobic sealant, however i see no appreciable sign of it, is this what one would expect it to look like after 25 years on the mated surfaces? these pictures are as yet untouched/cleaned surfaces.
i have much higher resolution images if needed, just trying to be light on site/browser resources.
thanks
oil sump to block, anaerobic sealant, 2001 xc70
lrock
- Year and Model: 2001 v70 xc
- Has thanked: 9 times
- Been thanked: 37 times
- volvo_oil_sump015.jpg (59.69 KiB) Viewed 221 times
- volvo_oil_sump013.jpg (52.63 KiB) Viewed 221 times
- volvo_oil_sump016.jpg (51.81 KiB) Viewed 221 times
- volvo_oil_sump008.jpg (35.75 KiB) Viewed 221 times
- volvo_oil_sump001.jpg (32.5 KiB) Viewed 221 times
- volvo_oil_sump004.jpg (30.83 KiB) Viewed 221 times
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 114 times
- Been thanked: 263 times
That looks about right, mine looked the same. I used permatex upon reinstallation, can't recall the part number but anaerobic sealant.
2003 XC 70 (sold)
- Has thanked: 1506 times
- Been thanked: 3818 times
That’s what it looks like correctly dosed. Most people use way too much
https://www.amazon.com/Permatex-51813-A ... r=8-1&th=1
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 42 times
Yes, i used the Volvo stuff, only need a small bead. Used green scotchbright to clean surface and tiny foam roller for sealant. Make sure to clean out the oil pickup mesh.
XC70Rider
- Year and Model: 2007 XC70
- Has thanked: 35 times
- Been thanked: 41 times
With the sump dropped replace all the O-rings and gaskets with this kit
https://www.fcpeuro.com/products/volvo- ... r-30750783
I rolled on Permatex Anerobic Sralant 8 years ago with no issues.
lrock
already ordered and receivedXC70Rider wrote: ↑25 Dec 2025, 00:11 With the sump dropped replace all the O-rings and gaskets with this kit
