Friendly reminder to check your drains for clogs
lrock
Year and Model: 2001 v70 xc
Has thanked: 9 times
Been thanked: 37 times
Post by lrock »
:D
this one is passenger side cowl drain
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 113 times
Been thanked: 262 times
Post by Blacklab467 »
Can you give some more detail on where that drain is please, I can't visualize it.
2003 XC 70 (sold)
lrock
Post by lrock »
Blacklab467 wrote: 21 Dec 2025, 06:50 Can you give some more detail on where that drain is please, I can't visualize it.
there's two in the cowl at the base of the windshield, this was the passenger side.
if it helps visualize, i am squatting in the engine bay where the engine normally is. but mine currently is not 8)
on either side of the cowl theres a spot where it dips in, i've noticed it likes to collect leaves, nuts, whatever is falling from the sky, this is where the passenger side exits
this should help
darylrobert
Year and Model: V70 240 740t xc70
Has thanked: 6 times
Been thanked: 42 times
Post by darylrobert »
Warm Tip : Clogs checked and cleaned
Swedish Clogs
Swedish Clogs
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 78 times
Post by chrism »
Irock, please tell me you aren’t supporting the car on that concrete block.
Has thanked: 1834 times
Been thanked: 1709 times
Are you sure those are Swedish clogs? Look more Dutch to me. So DAF, not Volvo.
darylrobert
chrism wrote: 25 Dec 2025, 12:09 Irock, please tell me you aren’t supporting the car on that concrete block.
Concrete can collapse without any notice, i used hard wood under a jack, big mistake it split and was very lucky sump didnt get punched.
Has thanked: 1497 times
Been thanked: 3809 times
Ditto on that block being a bad idea. If you religiously stay out from under, ok in an emergency ,, but we old guts don’t ever use them…that’s why we are old. Cribbing 4x4 is much safer. Lumber in compression with out point loads ( like jack saddles :8 ) is safer, jack stands best, with a wheel under for safety
lrock
Post by lrock »
no.. jack only. it's supported along the pinch weld with magnetic pinch weld blocks sitting on jack stands, sitting on custom welded sleds, sitting on enough pavers to raise the car to lower out the subframe.. i'm not doing any work under the car, but it's supported on both reinforced pinch welds, on both sides, then 2 spots on the rear subframe and the tow bar for good measure
chrism
Post by chrism »
Thanks, Irock. And thanks for the write-up!
