VTL I’ve been thinking about your reply on the ’What did you do’ P2 thread. I wonder if a good solution is to glue the good key near the immobilizer and simply buy two valet keys and skip the $200+ each of programming. Could even maybe find a local to cut the key and keep the tumblers in place and save that effort of disassembly.
Infamous ignition tumbler problem, now "Start Prevented Try Again" Topic is solved
- Krons
- Has thanked: 193 times
- Been thanked: 202 times
Re: Infamous ignition tumbler problem, now "Start Prevented Try Again"
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 606 times
I drive like that in fact. The real immo antenna with the only key glued to it is hidden behind the dash, I even put a donor antenna on the lock, unconnected, just for the looks. The lock has been replaced with the one, which has two switchblade keys and a valet.Krons wrote: ↑24 Jan 2026, 05:09 VTL I’ve been thinking about your reply on the ’What did you do’ P2 thread. I wonder if a good solution is to glue the good key near the immobilizer and simply buy two valet keys and skip the $200+ each of programming. Could even maybe find a local to cut the key and keep the tumblers in place and save that effort of disassembly.
vtl
They suffer tin pest. Perhaps they almost never fail in Florida and alike states.
Two 05 have never had any antenna failures. 02 had it. I reflowed it with lead solder and that fixed it.
- Krons
I put this plan in motion today. Had a mobile locksmith here to make a key for a recently acquired 2017 Ford Focus (likely to replace the 05 XC90…).vtl wrote: ↑24 Jan 2026, 06:54I drive like that in fact. The real immo antenna with the only key glued to it is hidden behind the dash, I even put a donor antenna on the lock, unconnected, just for the looks. The lock has been replaced with the one, which has two switchblade keys and a valet.Krons wrote: ↑24 Jan 2026, 05:09 VTL I’ve been thinking about your reply on the ’What did you do’ P2 thread. I wonder if a good solution is to glue the good key near the immobilizer and simply buy two valet keys and skip the $200+ each of programming. Could even maybe find a local to cut the key and keep the tumblers in place and save that effort of disassembly.
He’s a 20 year veteran and knows the pains of Volvo keys. He didn’t carry blanks but said to order them up and they’d cut them for me. $16 for a pair of keys on eBay and see an antenna on there for $50. Hope to be all in with two keys for $100.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
