2007 S60 2.5T Radiator Replacement
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
Both of these are good videos for P2 radiator replacement on the S60 and V70. If there are others that are better or if it's possible to remove the radiator from the top please direct me to the link(s), thanks.
A question I have is why did one mechanic disconnec the AC line while the other didn't? Is there a difference between the P2 S60 vs P2 V70?
Starts at 11:30 and she didn't disconnect the AC line before dropping the radiator.
He disconnects the AC line on one side only starting at 12:43.
Has thanked: 1505 times
Been thanked: 3818 times
I think there is a lot more working room in the V70 than the S60
MoVolvos
Post by MoVolvos »
abscate wrote: 11 Feb 2026, 04:39 I think there is a lot more working room in the V70 than the S60
Same fender so no extra engine bay room. Radiator should mount in the same front support.
https://www.volvocarsoempartsdirect.com ... r-30796492
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
I replaced my 2001 V70 radiator from the top. Details reported here
viewtopic.php?p=484005&hilit=radiator+t ... ce#p484005
No photos were included.
I don't know which is easier - top or bottom. I did from the top because I do not like laying on the ground working above.
Been thanked: 472 times
Post by cn90 »
I posted a photo somewhere showing the "sandwich" combination. Once you see the photo, it is easy.
jonesg
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
on turbos , remove bottom front air dam, elec cooling fan, drop the rad and intercooler together from the bottom.
Go back in the same way, a milk crate and blocks of wood will hold it up until you can get it fixed from the top.
Make sure you have new Oring seals for trans lines and new clips for those lines. FCP.
MoVolvos
Post by MoVolvos »
volvolugnut wrote: 11 Feb 2026, 08:06 I replaced my 2001 V70 radiator from the top. Details reported here
I was think about lifting out the radiator by itself but didn't see how to separate it in the car as everyone removed the Rad and IC as one unit. I don't have access to level ground right now so prefer not to go under the car. In your link you removed this brace "The steel cross brace has many bolts , but these are easy to remove and the brace lifts off. ". I've watched many videos but am not sure if anyone had dealt with this brace?
MoVolvos
Post by MoVolvos »
cn90 wrote: 11 Feb 2026, 08:42 I posted a photo somewhere showing the "sandwich" combination. Once you see the photo, it is easy.
That will require disconnecting the AC lines and removal from the bottom?
MoVolvos
Post by MoVolvos »
jonesg wrote: 11 Feb 2026, 12:52 on turbos , remove bottom front air dam, elec cooling fan, drop the rad and intercooler together from the bottom.
I have some clips and rings sitting around some place intended for another car. The crate is a good idea even though I'm going to attempt removal from the top, thanks.
MoVolvos wrote: 11 Feb 2026, 20:11
I may have been first to try this method of removing from the top. I did not like the idea of raising the car enough to take the radiator out the bottom so started removing things until it came out the top.
The cross brace is the black steel formed plate between the bumper and the radiator. This is the part that always becomes the tool tray when I work on the engine.
