Hello,
The car is a 2005 S60, with an automatic transmission, a 2.4 engine, 140 horsepower.
For some time now I have had a problem with a stiff steering wheel in certain positions (left or right turn of about 90 degrees, as shown in the pictures).
Since I know that steering u-joints, especially the one in the engine compartment, are often problematic in cars of my generation, in recent years I have conscientiously lubricated the U-Joint in question with liquid grease in a spray, which helped until now, but not this time - now even after lubrication, the stiffness remained, which tells me that the time for replacement has most likely come.
What I have noticed so far is the following:
1) The steering wheel becomes stiff in both positions, the rest of the time it feels normal. Once it reaches the corresponding position, more effort is required to go through it, then it gets better and so on until next time.
2) I have no leaks, loss of hydraulic fluid, strange noises, the steering wheel is not stiff all the time, but only in the mentioned positions.
3) The hydraulic pump has been replaced, along with the hydraulic fluid - I have not noticed any losses in the expansion tank.
My question is how do you replace the steering u joint and could someone tell me what the OEM number of the part is?
https://ibb.co/27GhMS5v
https://ibb.co/0pSZ38Sz
Stiff steering wheel in certain positions S60 2005
- Been thanked: 466 times
- I think the PN is in the photo below. Use genuine Volvo part only.
- If you are short of budget, then find a standard u-joint (I think it is 15x40mm type but check to be sure). This setup has no circlip, so it is similar to driveshaft staked u-joint. Use a C-clamp to press it out (brace the yoke ears with a piece of metal first). Once the new u-joint is in, re-stake it using a small-tip punch + hammer.
nedqlkow
- Year and Model: S60 2005
Budget is not a problem, I am willing to buy an original item, I love my car and do not want to compromise on quality.cn90 wrote: ↑28 Feb 2026, 08:18 - I think the PN is in the photo below. Use genuine Volvo part only.
When checking by VIN number, the number they provided me for the part is 3409939 - https://www.tascaparts.com/oem-parts/vo ... ft-3409939, which is different from the one in the screenshot.
Actually,
The u-joint replacement is easy if you have done it before (driveshaft etc.).
No compromise on quality.
However, it is easier to replace the entire thing.
nedqlkow
But as far as I understand, before detaching the u-joint column, the steering wheel must be locked and not turned until it is reattached, so as not to damage the SAS sensor.
Am I understanding correctly?
dikidera
- Has thanked: 67 times
- Been thanked: 175 times
Нашите нямат мисля. Нали ти е бифюелка? На моята, на видата няма SAS. Дори да не е бифюелка пак мисля, че нямат. Смисъл има лентов кабел, ама не се следи позицията на волана.
nedqlkow
Здравей,dikidera wrote: ↑01 Mar 2026, 06:23Нашите нямат мисля. Нали ти е бифюелка? На моята, на видата няма SAS. Дори да не е бифюелка пак мисля, че нямат. Смисъл има лентов кабел, ама не се следи позицията на волана.
Не е bifuel моята, бензин, 140 конски сили е. Има лентов кабел, който измерва ъгъла на волана и е напълно възможно да се съсипе, ако волана се разцентрира, а нов е над 1000 лева.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 69 times
- Been thanked: 479 times
Don't spin it like a propellor, just feel for resistence within its range.
- 10 Replies
- 1020 Views
- 802 Views
Last post by MadeInJapan
