Brake System Svce Required + Cruise Control Gone '07 v70
OliPhant
Year and Model: 2007 V70 2.5
Has thanked: 3 times
Been thanked: 11 times
Post by OliPhant »
Greetings,
2007 v70 140K (DSTC) is off and on showing 'Brake System / Brake Assist Svce Required' messages, AND cruise control is suddenly non-functional.
Brakes are good, brake fluid full, braking is normal. No VIDA codes during this period.
Any thoughts, links about this would be valued. Ty!
Vova585
Has thanked: 155 times
Been thanked: 142 times
Post by Vova585 »
For lots of people it is brake pedal position sensor. Dont cheap out and get ATE brand. But best would be to check with Vida/dice cor codes. But my educated guess would be that sensor.
Has thanked: 1505 times
Been thanked: 3818 times
You will likely need a code reader that can read ABS codes, not just ECM codes
Think $50-75 tool, not the cheap ones
A single wheel sensor problem will disable ABS and Cruise , too.
OliPhant
Post by OliPhant »
Very helpful! Thanks much.
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
abscate wrote: 07 Mar 2026, 10:45 You will likely need a code reader that can read ABS codes, not just ECM codes
Vida is saying my right front sensor signal too low. anti skid and abs flash on and off.
maybe next year.
br0dy519
Year and Model: 2004 XC70
Has thanked: 126 times
Been thanked: 116 times
Post by br0dy519 »
jonesg wrote: 08 Mar 2026, 05:10
maybe next year.
Easy fix this year. Change tone ring. You can do it!!
04s60 2.4
04xc70 2.5t
