2003 v70 no spark
2003 v70 no spark
I have no spark . we changed the impulse sensor still no spark . Any other thoughts out there.its a non turbo 2.4
- Has thanked: 17 times
- Been thanked: 35 times
Many possibilities from the main relay for the ignition (2/23 in the main relay terminal), the ignition switch, a camshaft position sensor gone bad or bad connection, PNP switch, ignition coils themselves- bad leads from your battery (corrosion, bad grounding, etc.), bad MAP sensor, MAF sensor, ECM, Immobiler system, the list goes on. Have you checked your diagnostic trouble codes?
VCA
- Year and Model: 2008 S80 T6 AWD
- Been thanked: 5 times
Couple of questions--do the injectors cycle? (If you have a noid light, hook it up to #1 cylinder's injector and see if it flashes in time with the engine turning cover.) Any messages on the DIM about immobilizer? Also, is this a North American V70 or from another region?mike48 wrote:I have no spark . we changed the impulse sensor still no spark . Any other thoughts out there.its a non turbo 2.4
2008 S80 T6 AWD
1999 S70 GLT
1999 S70 GLT
Yes this is a north american vehicleVCA wrote:Couple of questions--do the injectors cycle? (If you have a noid light, hook it up to #1 cylinder's injector and see if it flashes in time with the engine turning cover.) Any messages on the DIM about immobilizer? Also, is this a North American V70 or from another region?mike48 wrote:I have no spark . we changed the impulse sensor still no spark . Any other thoughts out there.its a non turbo 2.4
You checked the impulse sensor- have you checked the camshaft position sensor? This will also cause a no-start condition. A diagram for it's location is in this thread: https://www.matthewsvolvosite.com/forums ... =9&t=18416
- 1835 Views
- 11 Replies
- 2401 Views
Last post by lizardheart
