2003 v70 no spark
mike48
Year and Model: 2003 v70
2003 v70 no spark
Post by mike48 »
I have no spark . we changed the impulse sensor still no spark . Any other thoughts out there.its a non turbo 2.4
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Many possibilities from the main relay for the ignition (2/23 in the main relay terminal), the ignition switch, a camshaft position sensor gone bad or bad connection, PNP switch, ignition coils themselves- bad leads from your battery (corrosion, bad grounding, etc.), bad MAP sensor, MAF sensor, ECM, Immobiler system, the list goes on. Have you checked your diagnostic trouble codes?
VCA
Year and Model: 2008 S80 T6 AWD
Been thanked: 5 times
Post by VCA »
mike48 wrote:I have no spark . we changed the impulse sensor still no spark . Any other thoughts out there.its a non turbo 2.4
Couple of questions--do the injectors cycle? (If you have a noid light, hook it up to #1 cylinder's injector and see if it flashes in time with the engine turning cover.) Any messages on the DIM about immobilizer? Also, is this a North American V70 or from another region?
2008 S80 T6 AWD
1999 S70 GLT
Responsible for the care of a '92 960 and an '07 S60R
mike48
Post by mike48 »
Yes this is a north american vehicle
MadeInJapan
You checked the impulse sensor- have you checked the camshaft position sensor? This will also cause a no-start condition. A diagram for it's location is in this thread: https://www.matthewsvolvosite.com/forums ... =9&t=18416
