Car: 2004 V70 NA - 98,000 miles
About 3 months ago I had a soft noise when turning the steering wheel to the left or right at idle or low speeds. I replaced the old power fluid with Mobil1 Dexron III and it went away.
Now, after 3 months, the noise is back and but the fluid is still clear.
I'm suspecting the power steering pump, but I'm not sure.
Anybody else experienced this before?
Power Steering noise at low speed
Power Steering Noise At Low Speed 2004 V70
The specifications just say ATF fluid, so I assumed Dexron III.
Link: http://new.volvocars.com/ownersdocs/200 ... .htm#pg148
1997 850 NA Wagon - 261,000 miles - Is no longer
2004 V70 NA Wagon - Saved my life
2004 S80
2004 S80
IVIUSTANG
- Year and Model: 2006 XC70
- Been thanked: 4 times
CHF11 and CHF202 are both compatible.dejongmc wrote:Mikealder: Did you mean Pentosin CHF202?
Jesse
1998 S70 T5 SE 290,000 KM sideswiped total loss(Sweet ride!)
2007 S60 2.5T loaded 63,000 KM SOLD!
2006 XC70 350,000 KM, 2" BadSwede lift kit, steel skidplate, Hilton Stage 1 tune, big burly tires
2008 S80 V8 245,000 KM SOLD!
2015 V60 T5 Premier+ 98,000KM
Thank you guys for pointing me in the right direction.
Last Saturday I flushed my power steering fluid with Pentosin CHF202 and the noise has gone away.
CHF202 is the new an improved version of CHF 21S, and it is cheaper too. I bought it at O'Reilly for $16 per bottle (1 liter).
Flushing this system can be done by one man, but if you have an extra pair of hands available use them. When flushing, the fluid comes out very fast and it is only 1 or 1,5 liters you have to get out. It just took a few seconds. You need to have 2 new bottles of CHF 202 ready to fill. All together I used 1 and 3/4 of the new CHF 202.
2004 S80
2004 S80
I have the same story, bought a C70 that had no noise at all; when I picked it up to drive it home, the guy had topped up the power steering fluid with dextron. By the time I got home, it was noisy. Flushed it with the CHF202 and good as new.
tigmaned
- Year and Model: blacked-out V70 04
another power steering post...good.
if our owners manuals are telling us to use ATF, then what is this Pentosin CHF202?
like in another post i just did a drain and fill with actual power steering fluid... but don't want to wreck my p/s....
- 440 Views
Last post by Pennybags
- 790 Views
Last post by jimmy57
- 1417 Views
Last post by Pretribrapper
- 1184 Views
Last post by Roger_850T
- 11 Replies
- 3871 Views
