Does any body know why this clip is red and looks like it’s an important SRS component? It is listed as a retainer in a sandwich of tabs for roof trim and b pillar trim. It looks kind of important being all red and in your face.
I’m thinking it’s for the panel parts to break free when the pressure comes on the belt when the tensioners fire - anyone seen one after an accident ?
I started playing in this area when I discovered a seat belt unclicked and under pressure from my ‘relaxed posture’ can be retracted back with enough force to break a door lock knob.
- Stu70
- Year and Model: 2006 Sonic VR GT
- Has thanked: 34 times
- Been thanked: 26 times
1998 S70 10v BiFuel - Sold
2006 Sonic V70R - “this is going to be expensive “
- Has thanked: 305 times
- Been thanked: 517 times
I don't know, I've always kind of wondered about why that's red. It might just be a coincidence.
- RickHaleParker
- Been thanked: 958 times
There is something similar in the side of the seat near the end of the belt. The one in the seat is a safety pin, you are supposed to set it when working on the side of the seat. It prevents one from setting off the SRS Pyrotechnical.
Yes, that’s something you always want to make sure you put in place while working with the control panel off. You wouldn’t want to accidentally kick that trigger!RickHaleParker wrote: ↑29 Feb 2020, 19:44 There is something similar in the side of the seat near the end of the belt. The one in the seat is a safety pin, you are supposed to set it when working on the side of the seat. It prevents one from setting off the SRS Pyrotechnical.
- Has thanked: 1511 times
- Been thanked: 3829 times
I’m always feeling either positive or negative when I see an Ion, never neutral.
Watched my Albany pals do a strut replacement in an hour, diagnose my no crank, and otherwise engage in social intercourse. I drank mai tais like good management.
Four Volvo’s present including the Stealthy 019 Black one in the garage
I think my pal Mike might be the only more polar bear guy I know than me.
- smacknab
- Has thanked: 97 times
- Been thanked: 43 times
Jacked the front and tested the wheel for play. I was looking for play in the hubs, but they didn't have any at 6&12. However they did have about 1/2 inch play at 9&3 with a solid/audible clunk at the 'end' of each play.
I just replaced the inner and outer tie rod ends 1 month ago, does anyone have suggestions for what this could be? What to check next?
07 V50 T5 AWD M66 ~146k miles
