Stu70
Year and Model: 2006 Sonic VR GT
Has thanked: 34 times
Been thanked: 26 times
Post by Stu70 »
Does any body know why this clip is red and looks like it’s an important SRS component? It is listed as a retainer in a sandwich of tabs for roof trim and b pillar trim. It looks kind of important being all red and in your face.
I’m thinking it’s for the panel parts to break free when the pressure comes on the belt when the tensioners fire - anyone seen one after an accident ?
I started playing in this area when I discovered a seat belt unclicked and under pressure from my ‘relaxed posture’ can be retracted back with enough force to break a door lock knob.
1998 S70 10v BiFuel - Sold
2006 Sonic V70R - “this is going to be expensive “
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
I don't know, I've always kind of wondered about why that's red. It might just be a coincidence.
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
There is something similar in the side of the seat near the end of the belt. The one in the seat is a safety pin, you are supposed to set it when working on the side of the seat. It prevents one from setting off the SRS Pyrotechnical.
bmdubya1198
RickHaleParker wrote: 29 Feb 2020, 19:44 There is something similar in the side of the seat near the end of the belt. The one in the seat is a safety pin, you are supposed to set it when working on the side of the seat. It prevents one from setting off the SRS Pyrotechnical.
Yes, that’s something you always want to make sure you put in place while working with the control panel off. You wouldn’t want to accidentally kick that trigger!
Has thanked: 1502 times
Been thanked: 3817 times
I’m always feeling either positive or negative when I see an Ion, never neutral.
Stu70
Post by Stu70 »
With jokes like that, we gotta keep an ion you.
Watched my Albany pals do a strut replacement in an hour, diagnose my no crank, and otherwise engage in social intercourse. I drank mai tais like good management.
Four Volvo’s present including the Stealthy 019 Black one in the garage
crlande
Year and Model: 240DL;850;S70
Been thanked: 36 times
Post by crlande »
Because drinking mai tais, a pair of shorts, standing next to a boat, and making small talk always makes it feel warmer out! Oh yeah!
I think my pal Mike might be the only more polar bear guy I know than me.
smacknab
Has thanked: 97 times
Been thanked: 43 times
Post by smacknab »
Jacked the front and tested the wheel for play. I was looking for play in the hubs, but they didn't have any at 6&12. However they did have about 1/2 inch play at 9&3 with a solid/audible clunk at the 'end' of each play.
I just replaced the inner and outer tie rod ends 1 month ago, does anyone have suggestions for what this could be? What to check next?
07 V50 T5 AWD M66 ~146k miles
