Vida CEM swapping
Alucard666
Year and Model: 2001
Re: Vida CEM swapping
Post by Alucard666 »
RickHaleParker wrote: 12 Jul 2021, 15:42 What is the Volvo Part Number on the CCM?
Also get the chassis number. Which is the last six digits of the VIN number ( Vehicle Identification Number ).
Post both here.
Chassis number (last six digits of VIN): 019838
In VIDA i see several number for CCM:
serial number 000072052445
hardware number 0008651247 A
diagnostic number 08651251 A
Or should I disassemble CCM and read part number on it?
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Alucard666 wrote: 12 Jul 2021, 23:41 Or should I disassemble CCM and read part number on it?
Just remove it from the dash. Part Number should be on the backside.
bosse
Year and Model: V50 -11
Post by bosse »
Regarding CCM.
They break. Temp sensor.
I managed to get them to work.
Enter program mode and exit. And they jump to live.
But for die again..
Alucard666
RickHaleParker wrote: 13 Jul 2021, 01:11
Where is part number? On the backside there is no stickers.
RickHaleParker
Alucard666 wrote: 13 Jul 2021, 11:47 Where is part number? On the backside there is no stickers.
Look right below the Volvo imprint on the black case. Looks like there was a label glued there.
Paint markings are a dead give away that the CCM has been replaced with one from a salvage yard.
Looks like you got two options.
1. Get a hold of Yagger and find out if the one you have can be reprogrammed.
2. Get a 8691950 from a car with a chassis number no higher then 314999.
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 608 times
Post by vtl »
Something to look for when you debug the hw part of the cracker. At 500K baud the CAN tick happens every 2 us. Teensy running at 600 MHz is capable of detecting the signal level transition in about 100 ns (0.1 us).
The clean signal spread over latency buckets looks like that:
Code: Select all
                   us:    83    84    85    86    87    88    89    90    91
[ 00 -- -- -- -- -- ]:     0   194     1  1303     0  1319     0   183     0
[ 01 -- -- -- -- -- ]:     0   195     0  1314     0  1286     0   205     0
[ 02 -- -- -- -- -- ]:     0   155     0  1394     0  1246     0   203     0
Notice the odd buckets are almost always 0. Could be even buckets, but you get the idea: either odd or even.
This is an example of the bad signal:
Code: Select all
[ 00 -- -- -- -- -- ]:   312   236   561  3966  1446  2811   327   339     0
[ 01 -- -- -- -- -- ]:   258   189   552  4255  1404  2772   267   301     0
[ 02 -- -- -- -- -- ]:   250   201   522  4196  1461  2802   274   292     0
[ 03 -- -- -- -- -- ]:   267   190   552  4106  1492  2866   272   253     0
RickHaleParker
Anybody wanting to try a different CAN transceiver. Somebody in Texas has some Bosch CF160 for sale on eBay. 10 for $9.99.
urosm
Year and Model: 2015 Volvo XC70 D5
Has thanked: 10 times
Post by urosm »
Hello, I made a cem cracker.
Programmed it and connect it to the car, but it doesn't work. When I start the serial monitor without connecting to the car, the serial monitor starts to work, but when I connect it to the car, the serial monitor won't start.
What could be a problem?
Thanks in advance!
Volvo 744 TDIC SOLD, 1989. ; 1997. - 2000.
Volvo 855 GLT + LPG Estate SOLD, 1996. ; 1998. - 2020.
Volvo V70 D5 SOLD, 2004. ; 2013. - 2021.
Volvo XC70 D5 SOLD, 2007. ; 2017. - 2021.
Nissan Pathfinder DRIVING, 2007. ; 2019. -
Volvo XC70 D5 DRIVING, 2015. ; 2021. -
Volvo XC90 D5 DRIVING, 2008. ; 2022. -
vtl
Post by vtl »
Make sure you have common ground with the OBD-II connector.
RickHaleParker
urosm wrote: 24 Jul 2021, 01:08 What could be a problem?
Post the schematic, your parts list and pictures of your build. So we can see what you have.
