Confused 99 S70 Engine type
Vernh59
Year and Model:
Post by Vernh59 »
I am trying to order a tune up kit for my 99 S70 n/a and then I see the note "for ......without direct ignition." I have an engine code of B5254S is this engine direct ignition? How do you know by the VIN or engine code? I have searched the forum and I find many references to the engine code but not for the ignition.
Thanks in advance.
Vern
'99 Volvo S70
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Easiest thing to do in your case is just pull the timing belt cover to see which belt tensioner is on it... It would save you hours of searching. If it's the newer type then go with that- if the older type then go with the lower engine number replacement parts- it's one or the other.
9394volvo850s
Year and Model: 93 850 5spd 94 850T5
Post by 9394volvo850s »
Vernh59 wrote:I am trying to order a tune up kit for my 99 S70 n/a and then I see the note "for ......without direct ignition." I have an engine code of B5254S is this engine direct ignition? How do you know by the VIN or engine code? I have searched the forum and I find many references to the engine code but not for the ignition.
Thanks in advance.
they mean by direct ignition individual coils(5) ontop of the plugs, wich you most likely wont have if its a non turbo. if you have a coil and a wire coming from behind the air box then its not direct ignition. there would also be no wires and no cap and rotor with direct ignition. post a pick of the engin bay and its wasy to tell the diffirence. above the airfilter on the drivers side you can see the Red coil. non direct ignition. and of course all the wires in blue.
93 850 5spd 320k (the daily)
94 850 T5 190K (race car)
95 T-5R wagon yellow (summer wag)
90 745 5spd 295k (winter wag)
67 122 2 door 4spd 69k :))
