spark trouble
JDS60R
- Been thanked: 3 times
you need to tet the coil for
voltage
trigger signal
primary resistance
secondary resistance
ability to fire under load
Work backwards its faster
Get a spark gap tester and see if the coil is producing spark.
If not check for voltage at the coil and then for signal at the coil.
you can use a test light to test for voltage (clip to ground and test on coil positive)
Test signal with clip on battery positive and test to coil negative - while cranking engine the light should blink
Let us know what you found.
You need a resistor or a big spark gap to check for ability to fire under load.
voltage
trigger signal
primary resistance
Retired
- Year and Model: Many Volvos
- Been thanked: 75 times
Actually tonight might be the best time to check things, look at it in the dark and see if it is arcing.
- 2487 Views
Last post by Roger_850T
- 2861 Views
Last post by ndphotonl
