spark trouble
zuni97
Year and Model: 1994 850 wagon
Post by zuni97 »
What is the best way to test an ignition coil?
JDS60R
Been thanked: 3 times
Post by JDS60R »
you need to tet the coil for
voltage
trigger signal
primary resistance
secondary resistance
ability to fire under load
Work backwards its faster
Get a spark gap tester and see if the coil is producing spark.
If not check for voltage at the coil and then for signal at the coil.
you can use a test light to test for voltage (clip to ground and test on coil positive)
Test signal with clip on battery positive and test to coil negative - while cranking engine the light should blink
Let us know what you found.
You need a resistor or a big spark gap to check for ability to fire under load.
Retired
zuni97
Post by zuni97 »
Thanks, no more work today but I'll try your suggestions tomorrow.
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Actually tonight might be the best time to check things, look at it in the dark and see if it is arcing.
zuni97
Post by zuni97 »
As it turned out it was not a spark problem at all, but vacuum. Your advise helped me come to this conclusion. The old girl is running again, thank you.
Ed
