I have a 1994 stock 850 and virtually every item of discussion on this board as happened to me. Here's a list.
Hit horn once.....kept honking. Contacts broken in steering wheel and center console window switches.
Used Steering Wheel installed with console......... $700.
Bulbs going out on dashboard. Remedy.whack the top of the dashboard, and voila no problem.
Car wouldn't start over winter. Stuck lifter........... towing, new plugs and oil change ................. $315
PNP switch went bad......... wouldn't pass inspection.......... new PNP switch and module installed............. $400
Cruise control wont work......................... still up in the air.
The list continues........ always an adventure with the Swedes.
Aint it the Truth! Topic is solved
- 1776 Views
Last post by chitownV
