240 wagon timing gear instructions and how to set timing.
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
butchkimball
Year and Model: 1990 240 wagon
Post by butchkimball »
Hello.
I bought a used 1990 240 wagon 6 monthe ago and had a few problems with the wiring someone re did.
Now thats fixed the timing belt broke. I was wondering if anyone has the info on how to line up the gears when I get the new belt on, so it is in time. I know I could probable buy a manual but I am strapped for cash right now.
Thanks
Butch Kimball
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
The timing marks are in the attachment:
240 timing marks.pdf
(98.23 KiB) Downloaded 1251 times
When aligning the crankshaft marks you need to bring #1 cylinder to compression TDC. Remove the spark plug from #1 and put your thumb over the hole. Rotate the crankshaft until you feel pressure coming up the plug hole and stop when the marks align. To check that this is the compression you would normally check to see which valve is open but without the timing belt the valves won't move. Remove the distributor cap and see which lead the rotor is pointing at. If it is #1 you are on the compression stroke.
To align the camshaft marks turn it by hand until the #1 inlet valve is opening and line up the marks.
The timing marks on the auxiliary shaft are not crucial.
If you need instructions for the belt replacement do a search as it has been covered recently.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
BamaPanda
Year and Model: 1992
Post by BamaPanda »
Just browsing here, and had to reply.
On a 240 where the distributor is on the drivers side of the head, toward the front ...the intermediate shaft is CRITICAL. It actually turns the distributor.
Many B230 motors have the distributor at the end of the head ..right up next to the firewall. On these the shaft alignment is not a concern.
Here is a guide that will help.
http://www.stepbystepvolvo.com/Resource ... 0belt1.pdf
