SRS light on
mvsuzr
Year and Model: S80 T6 2001
Re: SRS light on
Post by mvsuzr »
Never, ever, short or bridge the battery posts or terminals. The power stored in a battery can quickly generate intense heat, cause wires to burn, and can overheat the battery and cause it to fail (explode) if it is shorted.
If you want to bridge the wires, remove them from the battery first.
Then, touch the wires together using a short jumper wire. To be even safer, use a fused wire with a 5 amp or lower rating.
And, be sure there's no fumes around that can be ignited, there may be a small spark.
Kimpo
Year and Model: 850, 1994
Post by Kimpo »
Hi guys. I'm having the same SRS light proplem. However, I'm not having any codes on my OBD, just 1-1-1.
Where should I start to explore the proplem?
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
Welcome to MVS,
What port are you reading the codes from?
If the light is on you should have error codes from port B-5.
Kimpo
Post by Kimpo »
Ozark Lee wrote:Welcome to MVS,
Hi Ozark and thanks for your reply!
I'm reading the right port, B5.
I know there should be some codes if there's something wrong with system, but there's not. :shock:
Could it be in the wiring underneath the driver's seat?
confused_al
Year and Model: 1996 TLA wagon
Post by confused_al »
Have you tried perform SRS module diagnose/reset procedure? That procedure is to disconnect battery for period of time and reconnect to battery while key is in position II (if you download the service manual you will see that procedure in details).
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
Kimpo
Post by Kimpo »
confused_al wrote:Have you tried perform SRS module diagnose/reset procedure? That procedure is to disconnect battery for period of time and reconnect to battery while key is in position II (if you download the service manual you will see that procedure in details).
No I haven't. In fact, I've never even heard of that procedure. I've thought always when disconnecting/reconnecting (done that, doesn't help) the battery, the ignition should NOT be on -> keys in your pocket, or nowhere near the ignition switch. :)
I've to test that thing tomorrow.
To what service manual are you referring to?
confused_al
If you read a few posts back...
confused_al wrote:...the link for SRS part of the service menu (just skip the side bag part). http://www.volvoclub.org.uk/tech/servic ... System.pdf
BTW, you're welcome.
98 MB ML320
06 V70
95 850 GLT(RIP)
Kimpo
Post by Kimpo »
Yeah, I just spotted that link after clicking 'submit' with my previous post. Guess I'm a bit impatient... :P
So, what I'm gonna do tomorrow is:
- Disconnect the battery
- Wait for a while
- Turn ignition on
- Reconnect the battery
Right?
I really hope that helps!
And Al, Thanks!
Kimpo
Post by Kimpo »
Kimpo wrote:So, what I'm gonna do tomorrow is:
- Wait for a while
- Turn ignition on
Right?
^^ Hmm, I was just wondering how that procedure differs from that when the battery is reconnected when the ignition is off? Or what difference it does to the system?
PS. For some reason I'm not able to edit my posts. Or maybe I'm just too newbie. :)
teddrummond
Year and Model: 960, 1994
Post by teddrummond »
Hey,
I just got a 960 wagon, 1994 and it had the srs light on. I found this site and diagnosed with the OBD. Code 1-1-1 also. But I realized my light was going off when I was driving but would always come back on at startup, staying on until I was underway.
My theory is that it is a voltage issue. I confirmed this by revving the engine while in park. So, weak battery or dying alternator, or corroded connections. But at least I know my srs system is okay.
Thought this might help people withsrs lights on and 1-1-1 codes from OBD.
Cheers!
