In my 2001 V70 2.4T I made the mistake of reconnecting the battery with the key off, NOT in position 2. The AC control (CCM) went OFF permanently and the SRS Urgent Warning light came ON permanently. Changed the AC control - no problem. Learned here on MVS that I needed a dealer visit or a diagnostic tool that could reset the SRS. Bought the ICarsoft Vol II. I reset the SRS (heard the relay clicking) but it would immediately come back on. The SRS codes were SRS-00D0 no buckle signal drivers seat and SRS-00D1 no buckle signal passenger seat. I know that two buckles didn't fail at the same time. Did additional research and learned that I had to reset the CEM BEFORE resetting the SRS. CEM had some totally unrelated code set: rear passenger door lock signal low. I cleared door lock code in the CEM and then cleared the SRS codes. SRS light is off.
Doing research I found pieces of the puzzle in different places and am posting this as a one stop source of info on those two SRS codes.
Hope this helps.
SRS Light reset- Codes SRS-00D0 and SRS-00D1 Topic is solved
- Been thanked: 4064 times
Excellent reference, thank you. If you do remember the CEM code that would be good to add too
- 27 Replies
- 27338 Views
Last post by cn90
- 1853 Views
- 1873 Views
Last post by precopster
- 1646 Views
Last post by esl_97_850_T5
- 6689 Views
