It really saves gas and gives power!
Do fuel additives help mpg?
- instarx
- Year and Model: XC70 T6 2011
... and an SE which is heavier than the normal AWD.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
2011 XC60 - sold
tjts1
- Year and Model: 96 855 NA 5 speed
- Been thanked: 4 times
Its totally doable.instarx wrote:If perchance you want to make a little wager that I can't get 32.5 mpg on a 500 mile trip in my stock turbocharged V70 XC schoolbus, just let me know any ol' time. I mean, it's "no way, it ain't happening", right? Easy money for you.KEWROCK wrote:So instarx, You're saying that on the high side you're gettig close to 33 mpg. NO WAY. These ar 4000 lbs school buses with turbo engines. It ain't happening.Heck, I even have a roof rack.
Ambitious but rubbish
Sladethesleeper
- Year and Model: 1998 S70T5
I stay away from oil additives like the plague.
Back in 2001, I got the bright idea to use Slick 50 in my 91 Explorer. It had 180k miles at the time. One month later, my engine no longer developed oil pressure at any engine speed under 1000RPM. Originally, I upped the oil thickness from 10w30 to 10w40 and eventually to 20w50 to help keep pressure up.
The odd thing, it does indeed have no pressure at the gauge when below 1000k rpm after the engine has warmed up. I replaced the sending unit and eventually ran a mechanical gauge to verify it was not an electrical problem. But, the engine still purrs like a kitten 140k miles later, even with no oil pressure at idle.
Now maybe it was just pure coincidence, but that is enough to keep me from putting it into another car.
As far as volvo mileage, I can't complain about my stock S70T5 with 195k miles on it. If I'm easy on the throttle and go around 68 MPH, I can still manage as high as 31 MPG and as low as 29MPG. I've seen higher, but that was with a noticeable tail wind. That's with the wife, dogs, and a fully loaded trunk on a 360 mile trip that we take every few months, verified with tank fill up measurements in addition to the trip computer.
1998 S70T5 - 210k miles
1998 V70GLT -110k miles
2004 Chevy Silverado 1500 Z71 - 305k miles
1965 Mustang Convertible
I like miles...
I like miles...
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
KEWROCK, simply because you can't get 33 mpg does not by any means that other people can't. If you have read over this entire site then you have read countless threads about people getting 30+ mpg. Is your car at stage 0 yet? Do you have proper tire pressure? Are you running 87 or do make the extra effort to get higher octane fuel? How old are your spark plugs? Are they gapped correctly? What kind of air filter are you using? What kind of oil? Are your calipers dragging? There are an infinite number of things that you may be doing differently then we are. As a result you can't get 30+ mpg while we can. You can accept it or not, but we are happy knowing that we can do something you believe to be impossible.
Just for kicks...
1) If these things actually worked car manufacturers and the EPA would have added them to the fuel supply long ago. It is a easy and cheap way (in bulk) to comply with the CAFE requirements. That's the regulation/law which states the fuel efficiency of a group of cars.
2) If it's too good to be true, it is.
3) instarx, I love your avatar. It rocks!
Merry Christmas,
Bright
Merry Christmas,
Bright
Many Thanks,
Bright
1995 960 Sedan
Bright
1995 960 Sedan
marginal
- Year and Model: V70 D5 2003
Why would the have?bright wrote:Just for kicks...
Merry Christmas,
Bright
Oh, I get what you understand.
For example, there are mandates for pollution control. Some of these are handled within the car (EGR, catalytic converters, etc) while others can be dealt with externally (fuel additives.) The gas you get varies during different parts of the year to help with pollution abatement. It's one of the reasons why you see the fuel pumps state that "This fuel may contain up to 10% ethanol." Ethanol helps control certain pollutants, along with other issues.
Among those other issues are corn ethanol subsidies. Since those were passed you'll never get them repealed. Ever. That is a side effect of the US Electoral College. But that is the politics of fuel and farming...
If the Lucas stuff really did what it claims it does, it would be easier to add it to all vehicles so they would all get better mpg. And it would be easiest to do this at the pump.
Manufacturing and distributing this stuff in little bottles is pretty expensive compared to making it and supplementing the fuel supply directly.
Many Thanks,
Bright
1995 960 Sedan
Bright
1995 960 Sedan
I have to say this...all of us 900 driving people would *kill* to get in the 30's. I would be happy with the mid 20s. But nope. I get 23 if I am very careful on the interstate (60 mph, no traffic). Around town, I get 21 or so. And I drive "cautiously." My elderly Mom gets irritated because I drive too slow.
I tell people I'm all about the cruise. But man, couldn't' I get the MPG too?
Many Thanks,
Bright
1995 960 Sedan
Bright
1995 960 Sedan
- 14 Replies
- 1620 Views
Last post by BlackBart
- 602 Views
Last post by volvolugnut
- 932 Views
Last post by VRZJL
- 2167 Views
Last post by jforce
- 1797 Views
Last post by erikv11
