Alternator Is Putting Out 30 Amps According To Autozone Guy
tolian2
Year and Model: 1995 Volvo 855 5sp
Post by tolian2 »
1997 854 2.4T 194.3K miles automatic
What is the reason for that?
Do I basically need to get a new/rebuit unit (100 Amps) from bosch?
I could see if I can get one from the JY, but the mileage will be comparable, or eBay, probably.
What do you, guys, think?
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Alternators just die after a while, just kinda a fact of life, and that one sounds like its gone. Winter is especially hard on them. Is it whining a lot?
I'd look into getting a new or rebuilt one and save yourself the effort of having to replace it again if you get a used one.
When's the last time you changed your serpentine belt? Might add that to the list too while you've got it loose:mrgreen:
'98 S70 T5
2016 Chevy Cruze Premier
tolian2
Post by tolian2 »
this car is new to me. I'm just starting to sort out the issues.
PO did not indicate, he changed the alternator. it says Volvo on it; I'm assuming it's an original one.
Belt will be done soon, along with the t-belt.
Pauloil
Year and Model:
Post by Pauloil »
volvo 850 alternator's output are to be tested under load at 2000 rpm with lights on, rear window defroster on, and fan on high.
do a voltage drop test on the the pos wire bet. alt and battery under load also. normal result less than 0.2 volts at 2000 rpm.
not uncommon to have bad starter cable: gets hot by battery. the battery posts need to be cleaned with steel wool or a post tool.
there is a link on this site to voltage drop testing....
99 V70XC 158K
95 850glt 188K
tolian2
Post by tolian2 »
thanks, that's really hepful.
they did measurements at idle 1000 to 800 rpm
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
This might help:
alternator and regulator.pdf
(130.92 KiB) Downloaded 550 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
