1998 S70 door panel Topic is solved
[email protected]
1998 S70 door panel
Post by [email protected] »
Can some one tell me how to remove the back door panel on my s70, the door locks go down when car is locked but will not go up when car is unlocked, both back doors failed
nlemerise
Year and Model:
Post by nlemerise »
You need to remove the inner door panel and then the solution will be obvious. The door lock button connects to the mechanism by a press fit. Take off inner door panel and press the loop from the lock button over the plastic fitting. If you don't see the plastic part, just click the lock button on your remote and it will be obvious. Go here for door panel removal instructions:
http://www.volvospeed.com/Repair/doorremove.php
