need help about camshaft position
cadu20
Year and Model: 2000 s80
Post by cadu20 »
hi guys,need help!!!!!
i bought a 2000 s80 that had bent valves because a wrong timing belt setting for the last owned, so took the head fora machine shop to rebuilt now i have but don`t know what position to lay the cam into the valve cover ( does anyone have a pics without the holding tool ). the end of camshaft ( intake ,vvt ) has 3 grooves ( 0,90, 180 degres ) and exhaut 2 groove ( 0- 180 degres), please need to know before install the new timing belt ( don`t need anothe head job anytime soon) .
thanks :( :(
JDS60R
Been thanked: 3 times
Post by JDS60R »
hope its a 2.9
2000 s80 2.9 timing belt change.pdf
(424.43 KiB) Downloaded 311 times
Retired
cadu20
Post by cadu20 »
yes it is a 2.9 but what i need is the position of the end of camshaft , i put one time and turn fews times and the valves did not touch the piston but after compression test result i know is out time ( 30, 40, 60,90,50, 80 )
need help please.
thanks
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
Can you see the other end (the non-pulley end) of the camshafts?
cadu20
Post by cadu20 »
yes i can see the both ends of the camshaft, i don`t have the hold tool keeping this cam to moving. there way to set in time without this tool.
help please
uncletom
Year and Model: 1999 S80
Post by uncletom »
I also lost timing on my S80 and had to replace 4 valves. My sugjestion to you is to find the VADIS CD on Ebay. I have designed and built engines for almost 50 years. The volvo is timed by only by using there absolute location of crank,both cams,intake and exaust gear settings. None of wich are set while engine is TDC as we are used to. The crank is also placed in a specific locatiom with a tool that is placed through a hole in engine located under the starter motor that lockes the crank in a specific location (not TDC). I used a 3/8 extension that fit perfectly and was lucky to borow the cam locking tool from a european auto repair shop in my area.Would never attemt without the Vadis information. Inexpensive and invaluble.
Good luck.
99 S80 2.9 / 99 Land Rover disco 1 / 86 Alfa Romeo Spider veloce
