door panels on '96 leather wrinkled
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
hollywood953
Year and Model: 960 1996
Re: door panels on '96 leather wrinkled
Post by hollywood953 »
I took the door panel off (not recommended for the faint of heart) and found that the top of the leather is held in place by 3 clips on the rear doors and two clips on the front doors. They range from 6 to 12 inches long. The "pinching" occurred in the space between the clips. The heat evidently causes the leather to shrink and draw away from the panel. I heated the leather with a hair dryer and sprayed adhesive to reattach it. The problem comes from peeling back the leather on the non effected area as the glue actually peels back the backing (pressed board). Once I got the backing off the leather I was able to use the adhesive and stretch it back out. It was about a 4 hour job to do all of the doors. Hope this helps someone else.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Thank you for the update.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
