s70 radiator change FAQ
warcoy99
Year and Model: 2000 S70 GLT/SE
Post by warcoy99 »
how easy is it to change? Am i right about removing it thru the bottom of the car while on jack stands?
is there a trick to removing the tranny hoses after i remove the yellow clips where it enters the radiator?
Has anyone had the little neck break off that holds the hose to the upper resevoir tank?
WARCOY99
HOOK 'EM!
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
warcoy99
Post by warcoy99 »
thanks ,its looks more complicated than thatbut i'll try it.Was there any special tools needed to take the tranny and oil lines off w/o breaking the clips?
WARCOY99
HOOK 'EM!
holler1
Year and Model:
Post by holler1 »
The clips can't be spread very much or they get stretched and lose their spring. I don't know of a special tool but a screwdriver or needle nose pliers can be used. You need to spread the clips slightly and slide the fittings off away from the radiator, rather than spread the clips wide and pull them off perpendicular to the hoses. You may have to put plastic ties or band clamps around the clips after you put them back. Here is a picture that might help, and a link to some other pics. http://picasaweb.google.com/wvholler1/V ... torFix2009#
1998 Volvo V70 AWD 165000-R muffler, HD endlinks, boost gauge
2008 Ford Fusion AWD 107000
2000 Ford Ranger 4wd 172000
1991 Toyota Camry 160000#1
Previous: 1982 Volvo DL (240) 160000
1998 Tacoma, Fords (6), Dodge, Montero,
GTO, Sunbeam Alpine, VW Dasher
warcoy99
Post by warcoy99 »
THANKS TO ALL,ITS BEEN A BIG HELP NOW I HAVE CONFIDENCE TO DOIT MYSELF......
I KNO I'LL BE BACK IF I GET STUCK!! :D
WARCOY99
HOOK 'EM!
