-1996 850 with 175k, I have had it since 162k
-It stalls and shudders randomly, always after warming up
-Can do it while idling, can do it while driving, sometimes will die and will not start back up for minutes
-It does not trip any codes
-Shifting into neutral and flooring it can prevent sometimes prevent a stall
-I tried driving with the MAF disconnected, and then the TPS disconnected, the problem did not go away
Here's a video of the car starting then immediately spuddering and stalling a few times:
Spraying carb cleaner at the base of this pipe, near the bolts, causes the car to lose power. I don't know if this is important:
And finally (yes Im going crazy) here's a spreadsheet ODBII pull for a few sensors in the few minutes leading up to, during, and after the sputtering (the lines where it loses power are bolded):
http://spreadsheets.google.com/ccc?key= ... tT2c&hl=en
I am going to clean the IAV tomorrow but I don't know if that's the problem.
