How do you determine which transmission you have in the S80's?
I have a 2000 S80 with the 2.9 engine, engine code B6294S.
Is there a tag or label somewhere on the trans that list it?
Vadis lists a bunch of transmissions:
4T65EV
4T65EV-GT
AW50-42
AW55-50/51SN
M56
M65
I am guessing the "AW" means all wheel drive, and the "M" stands for a manual. So that leaves the other two. Is the 4T65EV-GT the tranny that is in the turbo models? My transmission is not the sport shifting type. I may have answered my own question, since the only one left is the 4T65EV.
I am having what seems to be common solenoid problems that are famous for this transmission. I am going to have the tranny computer scanned again and see what it tells us this time, then decide on the fix.
S80 transmission identify-solenoid problems
2004 Volvo XC90 AWD - 170,000 miles
2010 Volvo XC60 AWD - 145,000 miles
1996 Volvo 850 Platinum - 201,500 miles - KILLED BY UNINSURED DEER _
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
You have the 6 cylinder engine, so that narrows it down to the 4T65. You do not have the manual shifter, so no GT (GearTronic). That means you have the 4T65EV.
I am not sure which transmission is on my car. Base on what you stated then I have a 4T65EV transmission ( 1999, S80 2.9 Non turbo, No Gear tronic). And I've took off the aluminum plate from the transmission body which stated U.S.A (A321804) = This mean the transmission was made in US (by GM).
However, base on the VIN number and the information from Swedishautoparts the my transmission is the AW42.
my VIN #: YV1TS97D6X1XXXXXX
Number "6" in the series above tells it is a AW42.
check the link below from swedishautopart
http://www.swedishautoparts.com/Volvo_P ... plates.jpg
Please help. I am not sure which transmission so I can buy part to fix
Thank you very much for all your help
Tim
Tim
Volvo 1999, S80 2.9 Non Turbo, Non Geartronic
05 Honda Accord 3.0, V6 EX
96 Toyota T100 2.7L - 265K miles, Still Strong and Smooth
I had this problem last year on my 56k mileage car.
It needed a strip down and solenoid replaced. this cost me over £1k.
Mine has geartronic which the gearing was intermitten. It wouldn't select first and fourth gears.
Alls well now.....until that is another electrical problem rears its ugly head!
- 887 Views
Last post by Skeletor
- 1415 Views
Last post by BlackBrick
