V70 2.4 2002 Rear Washer doesnt work.
floydyboy
Year and Model: V70 2.4 2002
Post by floydyboy »
My rear washer has stopped working since all the frost and snow we have been having, the front ones work but when i engage the rear washer the wiper works but no fluid, the resevoir is full and i have cleaned the nozzle????
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Can you hear the pump running when you use the rear wash? If not check the pump. If you can hear it, check the pipe connections from front to back. If the system has been frozen it could have pushed a pipe off.
There is also a non-return valve immediately beneath the nozzle which could have jammed.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
floydyboy
Post by floydyboy »
thanks for the reply, how do i get to the non return valve, have i got to take the rear door lining off to get to it, and how do i un jam it if this is the problem.
Edd
gchardy
Year and Model: 2001 v70 2.4T
Post by gchardy »
Floydyboy,
Start with the fuse panel first.
Just had my rear window with same symptoms. Fuse was blown!
Graham.
