Oil all over the place Topic is solved
Guest
My 96 850 non-turbo is blowing oil all over the engine. Looks like it's coming from the oil filler cap. Is this a common problem and fixed with a new cap? Any help is welcome.
White850Turbo
- Year and Model:
Very common problem. All you need is a new filler cap seal that shouldn't cost more than a couple bucks at the dealer. However, if you're having a lot of oil thrown up, that's a potential sign of a clogged PCV system and, which could cause lots of headaches down the road. Try the new seal first and if the problem continues, you may want to look into pulling the intake manifold and throwing a new oil trap on to alleviate positve crankcase pressure.
-Sean
1995 850 Turbo (Extensively Modded)
1998 S70 T5 (Almost Stock)
bodfyat2
I had the exact same problem! The oil overflowed so much it got into the spark plug wells and fouled up everything. I just replaced the oil filler cap rubber seal but I think I have the added problem of too much pressure because I still see new oil around the cap. You mentioned pulling out the intake manifold and putting in a new oil trap. Do you have any references on how to do that? Is it and easy thing to do.
All help VERY much appreciated.
thanks
thanks
White850Turbo
- Year and Model:
"Easy" is relativebodfyat2 wrote:I had the exact same problem! The oil overflowed so much it got into the spark plug wells and fouled up everything. I just replaced the oil filler cap rubber seal but I think I have the added problem of too much pressure because I still see new oil around the cap. You mentioned pulling out the intake manifold and putting in a new oil trap. Do you have any references on how to do that? Is it and easy thing to do.
thanks
-Sean
jimmix
Wondered if this problem is a volvo thing, my daughters 240 dl is hiccuping oil thru the oil filler hole too. Is this likely to be a PCV problem there too if not filler cap?
- 463 Views
Last post by MadeInJapan
- 707 Views
Last post by beigg
