S70 engine replacement
Carolyn Ritter
- Year and Model:
My engine is dead and needs to be replaced. I have looked for weeks to buy a used engine for my 2000 S70 T3 Engine and no luck. Does anyone have one that has low mileage?
White850Turbo
- Year and Model:
If you don't mind me asking, why do you already need a new engine? Check www.car-part.com for engines. It's a nationwide salvage yard search. The engines from the 1999 and 2001 model year S70's should work also.
-Sean
1995 850 Turbo (Extensively Modded)
1998 S70 T5 (Almost Stock)
Carolyn Ritter
- Year and Model:
The Volvo mechanic said there are metal shavings in the oil. My oil pressure light went on, then the car started making a horrible knocking noise. I had it towed to the mechanic. IT has 126,000 miles, but I was surprised to know it was going to be a total replacement. It is the T3 engine, and the Volvo mechanic says the other models are not interchangable. Are you sure about that? I have gone to the websit you referred me to, and no luck.
