Cleaning tip for coolant systems ....cheep & works!
gunner
Year and Model: s80 t6 1999
Post by gunner »
I have, on many makes & models used automatic dish washer detergent with additive called calgone , in chrystal form mixed with clean water to help clogged heater cores.
Step 1- drain all existing coolant & rinse with fresh water . Coolant must be properly discarded, or recycled.
Step 2 -replace drained coolant with mixture of detergent & water , premixed and top up coolant system , clearing air.
Step 3- run car - better yet a few miles with a "quickened rpm" to allow fast pace turnover of cleaning detergent. Monitor coolant gauge to ensure you don't overheat engine. ( dont do this in colder climates!) The further you drive , or longer it runs the better it will clean. (very inportant to remember you have no freeze protection - so dont froget to drain it )
Step 4- drain & repeat if required , then meerly flush entire system with clear water , I run garden hose in overflow tank, and loosen upper rad hose , with car at idle , t/stat opening untill all soapy water is removed. I also run water thru heater core hoses . RE-connect any hoses to close system.
Step5 - remove water as best you can . You need to add coolant (new) straight up( just a bit) if you think straight water exists in engine then deluted 50/50 , then test antifreeze to achive correct freeze point , run system & top coolant as required to allow air out.
This is effective at reducing scale deposits , change coolant regularly to help eliminate the need.
Hope this helps !
537playing
Year and Model: 2005 S60
Been thanked: 5 times
Post by 537playing »
Interesting. But i'll refrain from trying.
charlyW
Year and Model: 97 855 T-5 CD
Post by charlyW »
I can see the Calgon working [Thats what most premium coolant cleaning agents are also it is a premium washing machine water softener/limescale remover here in the uk] Cant see the washing detergent doing anyharm as long as its thoroughly mixed before being put in.
Any picture of how well it cleans up?
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
gunner
Post by gunner »
We used it mostly with cross contaminated coolant systems with excellent results , (transmission cooler failure pumped ATF into antifreeze) as well as older poorer maintained cars at my shop , they had heat in heater core with increased idle, it helped here (20-40%).
Just flush it out well ...there is no harm.
I also personally use coolant additive called nalcool 3000 used in class 8 & 9 trucks designed to reduce scaling inside coolant system , its $10 a small bottle and treats 25 gallons of coolant ... every water cooled engine I own gets this. It stays in coolant. Cheers
