2000 V70 base model engine knocking even with 93 octane... Topic is solved
AndyS
Post by AndyS »
I have a 2000 V70 base model and it still knocks even after I had the oxygen sensor replaced a while back. I have been running 93 octane since the problem began. Is the any other typical problem with these models that would cause this. Also change fuel filter often... Could I just put a colder thermastat to help with the knocking/pinging?
Thanks, Andy
hethr68
Year and Model:
Post by hethr68 »
I'm not specifically familiar with that engine, but some of the obvious things to check are the knock sensor (if it has one) and the EGR valve/piping. If the EGR valve is clogged up or not working correctly the engine can knock. The other obvious thing is the timing, but it's probably computer controlled.
Anyway, start with the obvious stuff for preignition problems.
Guest
Post by Guest »
Does a 2000 V70 base model have a knock sensor? and where is the egr tube?
Thanks again, Andy
Andy Segal
Post by Andy Segal »
Anyone?
Thanks again, Andy
White850Turbo
Year and Model:
Post by White850Turbo »
Andy Segal wrote:Anyone?
Thanks again, Andy
Knock sensor(s). There are two of them under the intake manifold.
-Sean
1995 850 Turbo (Extensively Modded)
1998 S70 T5 (Almost Stock)
Jot
Year and Model: C30 2010
Post by Jot »
The EGR oil seperator bock is located under the intake manifold on the transmission end of the engine . a fexible hose is attached to the air intake.
